Here is the email I received from WTMS:
RFQ: Walker Turner 700 / 900 / 1200 / 1300 Series DP and Radial Ram (Pre-Delta Machinery)
Although we do sell the bearings separately - we do suggest customers to send us the pulley for bearing replacement if the bearings are very tight, to avoid breaking the pulley. We can also service the spindle bearings. Replacement new spindle bearings require either the use of Lock-Tite 680 retention fluid on the bore, or an alternate procedure to band the spindle shaft with one light coat of automotive primer at the bearing interface location. Instructions are provided with purchase of bearings.
P/N 70702 Bearing - Extended Inner race (for pulley).............................$28.37ea
P/N 6202-625EER Bearing - Spindle.....................................................$ 8.50 ea
S&H USA..............................................................................................$ 6.80
______________________________________________________________________________________
Quotation below is for service Remove & Replacement of bearings. You may leave your chuck installed on spindle when shipping quill/spindle assy. If you would like it removed, please note this with your delivery. If you are sending both pulley and spindle for service, pls use the Return S&H for spindle only. If you would like the old bearings returned - please note as well.
Service DDP-6N Pulley R&R bearings incl bearings......................................$ 78.00
Return Shipping USPS USA.........................................................................$ 14.00
Service DDP57XX Spindle Quill Assembly R&R brgs included.....................$ 65.00
Return Shipping USPS USA.........................................................................$ 19.50
We accept check, MO or Credit Card. If you would like to pay by Credit Card, we will send you an e-payment invoice via PayPal (PayPal account not required).
Walker Turner Serviced Machinery LLC
PO Box 666
Coventry, CT 06238
