WALKER-TURNER 16 INCH BANDSAW CROWNED TIRES??
I've owned three bandsaws and none had crowned tires. Had no issues with blade tracking using blade from 1/4 to 3/4 wide.
David,
I’ve had three Delta 14”, wood/metal bandsaws (still have one)
The wheels were crowned and the tires just follow the contour.
IMHO
I thought all blade wheels were crowned?
David,
IMHO
Very odd, I've had a 12" Beaver, 14" import and now my 14" Delta and none have crowned wheels.
I looked at new urethane tires for the Delta and as far as I can tell they are flat.
As far as I can tell, most tires are flat, on Ebay anyway. But when you search for "Walker-Turner" wheels they offer crowned, urethane AND rubber! TRhe original manual calls for glued rubber. I dont want to get into gluing anything. For older more tempermental machines like mine, crowned seems to be the best bet. Ive got a question posted to a manufacturer of expensive crowned tires. Ill have to see what they say. I'm sure their reply will start with. "Buy ours, they are the best"!!
Thanks
dlb
Greetings All!
UPDATE on the Walker-Turner Bandsaw progress. I purchased two Blue MaX urethane CROWNED tires from the Bandsaw tire warehouse. I'm not plugging them, just detailing exactly what I bought! They went on with some elbow grease and a few drops of sweat. (proper lubrication )
The 1/2 inch bi-metal blade tracks beautifully.
However, I do not know how to gauge the tension necessary. I can not afford the $350+ dollars for a blade tension device.
The "flutter " method has been explained on You tube but I dont have much confidence in that method for a metal cutting saw. What are your suggestions? The saw will be used primarily to cut stainless steel tubing, 2 1/2 to 3 inches in diameter and not more than 1/16th or so thick, and at a slow speed according to the saws chart for that material. I see an APP for an iPhone that can measure the tone or "twang" of a tight blade! (Really) Any comments on that? I used to "twang" my other blades on less sophisticated saws with my index finger and listened for a high pitch.
Thanks everyone again for all your input and ideas.
Stitches come out in a week.! LOl
Dave
