Video of my DIY Mist Coolant setup
Spray mist doesn't don't really cool your part, they lubricate the cutter.
Misters work good for profiling and surfacing, but they don't work that well for drilling and pocketing.
I have a dual nozzle Fog Buster on my machine running output pressure of 12 PSI and it works great for what I do.
MidDay, I don't fully agree with what you are saying about Misters not cooling. I run a dual nozzle Fog buster also and find that it does provide some cooling. Probably through the expansion of the pressurized air and also some evaporative effect. I agree that it might not be huge amounts but I think it is enough to mater. I think the biggest value is the air blowing chips away from the cutter so they are not re-cut and possibly a little bit of lubrication. I run mine at around 20psi and pretty much only cut Aluminum and occasionally 360 Brass.
