- Jan 22, 2011
- 8,031
You can't really peen it too much, unless you do it long enough for it to cool off. Be thorough, and basically leave no part of the weld bead unpeened.
I have used a gas bbq grill to get a larger casting up to pretty even heat, then a rosebud to keep the weld area a bit warmer. Vermiculite or sand, or at least back on the grill running wide open for an hour, then down a little at a time works for me. It will run thru a bit of propane though, or if you don't have one, just bury it.
