I have another question about the M head that I now own. It is wired 3 phase, with a 1/2 hp drive motor, and a 1/8 hp for the power feed. I know very little about 3 phase wiring, so I have decided to take everything [motors, boxes, wire, switches, and the new VFD converter that I bought], to a local electric motor shop. They said that they could go through the wiring and get me set up, and I trust them. My question is, how do I want the mill motors wired? They said that the converter box I bought may be able to run both motors, but do I want both the vary speed at the same time? Or the drive motor variable and the power feed constant? The drive constant and power feed variable? The drive is variable now by changing a V belt position, and the power feed is variable via a gear positioning lever. It is also reversable on the gearbox. I am sure that I will be asked how I want this to work and, as I have very little experience with a mill I am not sure how to answer. Any suggestions would be appreciated.
