- Mar 3, 2013
- 1,447
I've been having some trouble determining what the amp draw would be on the single phase side of the VFD when powering a three phase motor. I have a 20A 110v circuit so I can't imagine it would take more than that, but I want to make sure.
You should check the specs for your VFD. Below are specs for a Teco L510. Note that the Teco L510-101-H1-U (1hp 115V input) draws 19 amps. That's cutting it close for a 20A circuit, probably ok if it is a dedicated outlet. Most of the time it will be much less.
