- Jul 22, 2022
- 129
i received my scales from vevor and went to do the id following the instructions at https://www.touchdro.com/resources/scales/glass/glass-scale-pinout.html . the problem is when i opened the scale reader i discovered it was flooded with black rubber goo so i cannot get to the electronics to probe out the pins.... how do i determin what i need to wire the db9 connector to the touchdro diy board? it came with a piece of paper showing what the pins should be just needing a sanity check thanks
Mike
Mike
