- Nov 14, 2016
- 3,285
And the standard is quite low.
How many people buy these things, try to use them and just push the whole mess to the back of the garage? At least there are resources like this one that will help folks get the machine up and working. I know it's not practical for lots of folks but searching out a decent used machine will make for a much better experience IMHO. Older belt drive lathes, or little Craftsman/Atlas lathes are around if you're patient and usually yield better results in the long run. Since you're getting into a project anyway why not make it a worthy one?
John
I think the biggest issue with the 7x lathes is that they are quite attractive to beginners due to the cost and size. This is the group that is most needing something that works right out of the box. For somebody with at least a little experience so they have the skills to identify and correct the deficiencies they can be a pretty good deal for a small relatively portable lathe. Even more compact than the Atlas / Craftsman 6" lathes but potentially with similar capacity.
In that regard they are quite similar to buying used which can be a fantastic bargain if you know what you are looking at and how to fix issues, but likewise can be a nightmare to somebody just starting out. So easy to buy a basket case thinking you found a bargain.
Having now had a little time to play with one, I think the Atlas / Craftsman 6" lathes are highly under rated as a small lathe option. The biggest issue being that the newest are still 40 years old, and the oldest are over 80. The Atlas ones are a bit more straight forward, but there is a bit of a maze to follow regarding the options and parts for the Craftsman branded lathes sold before 1960. Then you have the confusion caused by the similarly sized but completely different 6" Craftsman lathe made by AA. Anyway wandering way off point.
