- Jan 2, 2014
- 9,381
The bars ? Just run an end mill thru the end of a shaft at whatever angle you want . Mill a small flat on top and drill and tap for set screws . If you want to get fancy , you can put an end cap on it , waste of time in my book , but you can .
........or even fancier, drill the hole for the tool bit and file it square with a small file. Set screw is the same.
For the ones with the tool-bit at 90 degrees, the set screw can be thru the end of the bar.
The kind with the tool bit at 45 degrees are great for boring a flat-bottomed hole.
Brian
