Hello Forum Members,
I need to plan for a way to very slightly enlarge a hole. By very slightly I mean about 0.0001 at a time.
I'm trying to create a tight sliding fit part in brass on a 0.25" steel rod (nominal). The rod is reasonably well-dimensioned after a lot of hand work, but not perfect.
I have tried reamers in 0.250 and 0.251. The 0.25 is slightly too tight (it binds), and 0.251 is slightly too loose (it slides smoothly but rocks ever so slightly). I could buy yet more reamers, though I'd rather not if there are other options that are more generally useful.
What tool (a hone maybe, assuming one would fit?) or other method can evenly expand a hole very slightly?
Thank you.
Thank you.
