Vee Jaws
When I use a v-block to hold round things in the vise, there's only one groove. I think that if you groove both jaws, then you'll have an issue with the grooves not lining up.
regards,
Leon
All my machinist's vise have a horizontal and vertical V groove in the fixed yaw only.
David
I just ordered a 6" X 2" X 2" T slot quick change Monster Jaws and some low profile cap head screws to go with it, for my Kurt D688 (getting it in a couple days). My intent is to make a set of Vee jaws for holding round stock, horizontally and vertically. Just like the typical ones you see for sale, but I want to make my own. The Monster jaws are so reasonable, it didn't make a lot of sense to pick up raw stock.
My question is, what is the preferred way of cutting the 45 degree Vs in the jaw? Should I use a 45 degree cutter? Should I tilt the head to 45 and just use and end mill? Is there a most sensible way to make the cut with the jaws installed in the trammed vise?
Unless you have plans to use the 45 degree cutter besides making these "V" slots I would tilt the head.
If I was going to make a set I would drill and ream two dowel holes both slip fit near the bottom of the jaws, say 3/8" or 1/2" diameter. I would use three inch dowel pins while bolting the movable jaw to the vise after mounting the fixed jaw. That way they act as a movable fixture. Be sure to remove the dowel pins before using.
Good luck with your project and post some finished photos.
I just did this a week ago. I first scribed the V I wanted and then band sawed the excess material leaving about .050" to the line. I tilted the jaw in the vise and using a .750" endmill machined out the rest of the material. I didn't reposition the jaw but made both cuts with one setup.v-block soft jaw.JPG
You can see where one jaw was end milled and the other was side milled by the different looking surface finish.
The second monster jaw will get a V cut with a greater angle than 90 to accommodate larger diameter parts.
I will post some pics, but it might be a little while as I am in the process of cleaning out fossilized grease and scooge from my Millrite.
I'm deliberating as to whether I should paint it prior to reassembly as I don't plan to have it apart again for a very long while!
While I was planning to take almost everyones suggestion to tilt the milling head, Jims suggesting a carbide router bit intrigued me.
I cut all sorts of aluminum on the table saw, so why not a carbide router bit? Well, I am not much of a theoryist, so I ordered
a Whiteside 90 degree 1 1/2" V groove bit and will try it out. If it works (taking shallow bites) the one bit will handle any size
"V" I would want.
Sanddan, thanks for the reminder to cut must of the material away with a saw prior to milling. I often forget to do that and spend way too much time on a project.
I'll let you know how that turns out! Thanks for all the suggestions.
I just did this a week ago. I first scribed the V I wanted and then band sawed the excess material leaving about .050" to the line. I tilted the jaw in the vise and using a .750" endmill machined out the rest of the material. I didn't reposition the jaw but made both cuts with one setup.View attachment 113266
Sanddan, so if I understand correctly, the new jaw is at a 45 degree angle in the vise and one surface was finished with the side of the endmill, and the other surface finished with the end of the endmill. Right?
+1.
I made sure the depth of the V was within the cutting ability of my endmill so one setup would work. I needed this for machining the base plate for the wilton mini bullet vise.
