- Dec 28, 2018
- 10
Half nut engages when you pull the lever up....I assume that the lever at the lower far right of the carriage is the threading feed (half nuts.) It appears(?) to be engaged. When threading is engaged, the feed function should be disengaged, by a lockout that keeps both from being engaged at the same time, which would break things. Move that lever up and then try to engage the cross feed.
(Just looked at the manual, and it confirms my thoughts.)
