I think that type of knurler should not even be sold for an AXA set. Because the lathe is likely too small to use it without damaging something
Some say they can damage the spindle bearing with high pressure it needs to be driven into the piece.
Long before the spindle bearing is harmed you are very likely to damage the cross slide lead screw nut with the pressure needed for a good knurl. Be careful putting high pressure on the cross slide lead screw on a small lathe.
I have good luck with the bump knurl holder. The tricky part is getting both knurls to bear on the work evenly.
I have a 1947 SB9C, the spindle is still nice and tight, the cross slide has .010" backlash, the compound has .005" backlash.I think that type of knurler should not even be sold for an AXA set. Because the lathe is likely too small to use it without damaging something
