You are describing a single deck switch, that has a single input and outputs to each rotation position as it is turned for one input to the VFD. You need a switch with at least 3 decks since you have three separate inputs to your VFD that need a signal, the number of positions doesn’t matter as long as it is 8 or more, you can put in stop pins to only use 8 positions in a 12 position switch for example if you find one of those in stock at a better price. Each deck would control one of your inputs to the VFD. You would wire it up with the common from the VFD going to the input of switch, the outputs only get wired for the position that needs a signal going back to the VFD. Assume the first deck is for TB3-1, you need to wire positions 1, 3, 5, and 7. You can daisychain the wiring on each deck, ie connect 7 to 5 to 3 and to 1 with a single wire going from 1 to the VFD. The next deck would be wired to 2, 3, 6, and 7. And the third 4, 5, 6, and 7.
This is the datasheet for a switch that looks like it would work.
I found this at Digikey, Mouser and Newark would likely have something too.
71ADF36-03PAJN | DigiKey Electronics
Order today, ships today. 71ADF36-03PAJN – Rotary Switch 2 ~ 10 Position SP10T 250mA (AC/DC) 115 VAC Panel Mount, Through Hole, Right Angle from Grayhill Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
