It is a GL-5 rated oil, the extreme pressure additives can be a problem with yellow metals, but they are only activated with heat. I used a similar (Amsoil) synthetic oil in my gear head mill and it was a significant improvement over stock gear oil with reduced heat and foaming. The Amsoil was for marine hypoid drives, but was not damaging to yellow metals. A 75W-90 is around an ISO 68 (46-100) depending on temperature. The issue with yellow metals is both under high pressure and heat the EP additives pulls the softer metals apart, but should not be a problem with sliding bearings. Probably work very well for the open gearbox of the 1340GT since it is ambient temperature and total loss system, but probably would not use it in the carriage although it should work ok. Be interesting to see how it works as a cutting oil. You could contact Lucas and ask about the issue with yellow metals, the other thing is limited slip differential oils behave a bit differently then standard oils which are actually too slippery to used in a limited slip with a clutch pack style.
