I recently needed to put an L shaped clamp into a design. The vertical part rests on a step. The "riser" of this step was hoped to keep the clamp from turning. It didn't work as well as hoped so I put some rosin on the "tread" of the step. The added friction solved my problem.
I originally bought the rosin to coat a taper that sometimes got loose. I did not want to Loctite it in.
Rick
Rick
