Well I contacted Chicago Dreis and Krumpf and they wante $66 PER INCH for my 48" brake in any radius. You dont want to use a36, use something like 4140 or tool steel, and get them properly heat treated. If they are not heat treated properly, they chip, if too soft it will deform. Our Trumpf brakes have finger dies that are heat treated on the tip only, which looks like flame hardened to me. I have a tool maker that is willing to make cutters so I can make different radiuses. I just need a large enough mill. I need different radiuses since I do different types of sheet aluminum and the radius is critical to prevent cracking. We have a 24" box brake at work that is made in Sweden, $3600 before the fingers, used bakes are not cheap, good brakes are not cheap, but you can rebuild any good name brand if you can find a good deal. Chineses stuff is butter soft cast that usually does not meet the specified rating because they bend or break. My Chicago is welded plate steel, not cast. Tim
