- Jan 2, 2014
- 9,266
Yes I can see that. The teeth on the blue one actually look a little fatter than the black one....... hmmmm.You can see in the pictures below what I meant by the mesh not being very deep.
There was one issue when printing these. I had most done but then left the two last black one (or two?) to print overnight, since it can take hours to print. The next morning I noticed it looked "done", but the printer spool was totally out of filament. I guess there was not enough left on the black spool to finish the print, but the gear(s) initially looked okay.
Later on I was playing with them getting ready to ream the bores and notice two gears were not as thick as the others, and I realized those were the last ones printed. So I found a new spool of filament that happened to be blue and reprinted just those two gears that were "thin".
When I packaged them up for shipping, I decided to just throw all of them into the package as I had no immediate use for gears of those dimensions, and maybe they'd be useful to you.
Therefore I believe there should be some duplicates in the batch I sent; likely one or two extra black ones that are just a little thinner towards one edge.
However I thought the blue ones would be better.
I am almost certain I used the same stl file for those duplicate/replacements. I need to save and use the intermediate files, so I would not likely re-generate them different.
Perhaps that blue filament should have had different bed and/or nozzle temperature settings on the 3D-printer.
Perhaps they either spread/flowed a little during the print, or even warped due to heat?
Do two black ones mate together better?
Please don't take it wrong,I am not complaining at all,I am just mentioning the next point for your information.
No worries on the feedback!
That was our deal, I would supply them for real honest feedback.
I appreciate it, please post any and all comments you have.
Brian
EDIT: and can you get a shot of both the black and the blue plastic ones mating with your steel originals? -Thanks!
