On my Universal grinder there's a lock ring just above the ring/handle to tighten the 5C collets. If I loosen it, it allows the degree wheel to free spin, so I can zero it out and then re-lock it into position.
as part of my deep research on this style machine I found the original Deckel style collets are worthless to me because they are metric and odd. And don’t even go up to 1/2” only 12mm. So I found one that was R8 and was not aware there was one with 5c. I found I couldn’t just order the R8 head and have it fit the Deckel style dovetails. They are not universal.I have no experience with 5C collets and assumed that was what my machine used. But now I know that the collets my machine uses are quite a bit smaller and aren't in the "C series". They are some special type of collet that Deckel sharpeners use and are cloned by the Chinese. Before I knew what I know now, I ordered a 5C collet to ER20 adapter. I immediately realized my mistake when it arrived and saw that 5C is quite large. If I had just looked at a 5C mechanical drawing and compared it to the 3 collets that came with the machine first then I wouldn't have spent the $40+ on a collet I have no machine for.
There is no size difference between the various collet mods. They all weigh about 110lbs and I did strain my bicep wrestling that thing on to the bench.C-Bag: I have experienced many of the same things you describe. My case is a bit different than yours because my machine is small (and "mostly" metric) and will probably never use an end mill bit larger than 3/8". Also, I do as much in metric as I can. But because I am in the USA I buy cutters and stock in imperial because it is cheaper and more available. I think because my sharpener uses a Deckel type collet it is a smaller unit and it probably accounts for it being as cheap as it was. Even so, it is so heavy that it took some risk to my health to get it up the stair way and up onto the counter where it now sits. I wouldn't want it to be any larger (and heavier) than it already is. Pretty much all the work I do is CNC. So, even though I like to dream about having a larger machine, the price gap seems to sky-rocket (and the choices narrow) when you insist on CNC. It seems you almost have to do the conversion yourself. Most of the large CNC machines seem to be bundled with all of the control and software which drives the price way up and locks you into the manufacturers's way of doing everything. I wrote the control software I use and put the electronics together myself so I don't need or want the bundled controls. If worst came to worst, I could buy the next smaller metric collet and grind or file the opening larger to fit the imperial size bit I want (of course with the risk of losing accuracy). So far I've only found 1/4", 1/8" and even 1/2" collets in the sizes offered for imperial. But I don't use many cutter sizes so I don't need anywhere close to what might be considered to be a "full set". The offering on EBay does show going up to 16mm in metric. The web page does show a mechanical drawing and so I am pretty sure that these collets will fit my machine. I have a 1/4" on order so I will find out very soon whether or not I've made another mistake.
Dat512: I'll watch the videos. Thanks.
