The new motor is in!
It was more of a fiddle than I'd imagined.
Yet again, I simply could not get the pulley stack off the shaft of the old motor, despite heat, cold, levers, gear pullers and (eventually) extreme violence. In the end, I had to cut the shaft of the old motor off: the part I really needed to keep being the base plate (to mate to the Bridgeport's head). That took a full day.
The next problem was that the motor I'd bought had a 1" diameter shaft, 1.5" long. I needed a 3.5" long shaft to take a pulley with an id of 3/4". I ended up making an adapter out of a length of 2" diameter steel. Turning that down, drilling through it and boring it out took the best part of another day. At least I got to use my 10" Sheldon lathe for a project.
Adapting the new motor's base plate was easy (angle grinder) as was cutting out the holder for the bearing on the old base plate and drilling it to fit the new motor. I would have used my Bridgeport but, of course... so, I had to resort to drilling free-hand and it went surprisingly well.
With the new motor in place, it became obvious that I'd made the shaft just a tad too long. My pulley wheel was catching on the final drive to the mill's spindle. Whereas the old motor was a squat, fat thing, my new motor is thinner and longer. This matters because my workshop has quite a low ceiling and the new motor just about touches the roof spar. Lifting up the motor to put a spacer washer underneath proved to be quite tricky.
The electricity was a doddle. The motor came with clear instructions (in the connexion box) for choosing either Wye or Delta and my only niggle was swapping wires to get it to run in the desired direction.
I used my hand-held rev counter and I seem to be getting about 39 rpm per Hz. I mean that at 60Hz I have a spindle speed of 2,340 rpm; at 80 - 3,120; at 30 - 1,170. I think it will be useful for the jobs that I'll be asking of it.
My only problem now is that the belt is a bit slack, even with the tension set to maximum. Under load the spindle has a tendency to stall while the motor keeps spinning. I think the solution is to fit a slightly smaller belt. Or, maybe, a new standard sized belt that hasn't stretched with years of use. Does any one know the dimensions of the standard belt? That would be useful...
Onwards and upwards!
Kind wishes,
Nick
