So in the past couple of months I have had to repair some parts and on a few occasions it was decided that we would build up wend on the part and then turn down the weld to the correct dimensions. I have been having an issue with the weld metal ruining the cutting tools. I have tried both HSS and carbide tooling. It just seems that the weld metal is so too hard, most of the filler metal we use is in the 70K PSI strength range. Also the welds are not cooled rapidly, they are just left to cool down naturally in the air. I was thinking next time I could maybe wrap some insulation around the part so that it cools slower. One particularly nasty part was a pulley that was spun on a shaft. The pulley was welded on the id and I had to turn the weld metal to the required ID. I had a heck of a time as the weld was so hard that the 3/4" boring bar would just flex and chatter while trying to cut. How have other dealt with these issues?
