- May 7, 2015
- 269
Hello All,
Since I do not have a DRO on my lathe or dial indicators. What is the correct procedure for turning to a shoulder and then facing the shoulder.
I start out facing the end of the stock with the facing tool, then I switch to the right hand turning tool to rough out the O.D. (this forces me to change the angle of the tool holder) Then I have to switch to the facing tool again, which causes me to have to change the angle of the tool holder again. When I attempt to then match the correct O.D. I have problems holding the same dimensions at the shoulder, or if I have to increase the depth of the shoulder I end up messing up the O.D.
Also question on the new tool holders, Is is true that the new indexable tool holders have the geometry to both face and turn without having to change the tools?
Thanks
Joe
Thanks
Joe
