- Oct 4, 2011
- 727
Excellent video and made making tapers simple. I do have one question about the process.
In making your offset on the tailstock you mention that where you make the measurement is a reference point. Would taking that measurement from the live center not actually increase your L in your equation? In effect making your measurement length of part plus live center nose length? This causing your offset to actually be less than needed? I know the difference would be minimal but if someone is using a long live center it could easily add more than an inch to the equation.
Please don't take this as splitting hairs as I know I certainly have picked up a TON of knowledge from this forum and many others. I am just trying to get the whole process in my head. I think it will be cool to make my own center drill that fits in my tailstock and to be able to understand how to make other parts as needed.
Thanks, Chris.
Hi Chris
The question is a good one. I remember having the same one when I first tried this. The trick to remember is that the entire tail stock moves perpendicular to the ways of the lathe. This means the pivot point is the face of stock. Other wise the length of the tail stock would have to be in the formula and the same reason that the depth of the center drill does not affect the angle. So it does not matter where on the tail stock you measure the movement as long as its a stable location.
Hope that helps,
Jeff
