Thanks Tom ,I'll write this downRPM = SFM x 4 ÷ diameter
Tom
Tom
If you want a simple formula, at least use one that is accurate.
SFM=(11/42)*diameter*RPM
RPM=(SFM*(11/42))/diameter
That will get you to 0.5% of your target. It makes no sense to rely on a formula that is less than 20% accurate even without the typo, especially when it makes the difference between a sheave or two too fast when picking your turning speed. We have all this expensive gear for measuring tenth-thousandths and micrometers, so why slop around with kludgy math in this case?
sousing this formula and the littlemachineshop chart a piece of 12L14, 1.375" diameter spun at 750 rpm would be 270 SFM ?
I think what I am more interested in is what rpm various types of metals need to be turned at. So if I know the SFM and the diameter of the work piece, what is the formula?
