- Jul 12, 2024
- 3
Does anyone have experience turning off a stuck backplate? I've tried all the methods and gone through all the threads for getting this thing off to save the backplate, but it is truly stuck. I've seen people mention turning it down to the screw but no post from people who have actually done it or anything to look out for. Another method I saw was using a slice down the side of the backplate and putting wedges inside to snap it and loosen the tension on the screw. I don't have a mill however, so this operation would probably have to be done with an angle grinder and a cut-off wheel which doesn't sound like the most fun operation.
Any have any tips for cutting this thing off? I'm not exactly the most excited to be stuck using a 3-jaw forever.
(edit: Moving my reply I made with more information here for future people:
Thanks for the responses guys. I should lay out a few things. I have been oiling it daily, but I don’t think rust is an issue here, maybe chips stuck in the threads, . I had been using an Allen key in the chuck and a strap wrench to stop the spindle from moving and tried torquing and hammering to no avail. From there I made a large bolt with 3 flats to fit into the chuck and tried both an impact and then a 2’ wrench using full force on both the strap wrench and the 2’ and striking it with a sledge. No movement from that, even with the addition of heat. The jaws are starting to get a little beat and I really don’t want to hurt the spindle. I don’t have a ton of time to get this off and I have some projects I need to get the 4 jaw on for. The 3 jaw isn’t the nicest anyway and I’m okay with destroying the backplate in order to get what I need to get done, done. If I had more than a month left before I have to leave for school I’d be more than okay with leaving it to sit for weeks.)
(edit final: I will probably disappoint some of you guys but I ended up cutting it off using Stu's method who commented below and made his own post about doing this a while back, which worked beautifully and quickly. We used our Milwaukee porta-band which cut through it quickly and safely and everything went really smoothly, we cut a small wedge into it to get the cold chisel in, and with a few whacks the crack went down to the threads. I put the chuck back on and with about 15 seconds of torquing the chuck came off very easily. All in it only took about 20 minutes. Some of the threads in the backplate were chipped/marred and I think that was the root of the issue, combined with some chips in the threads as well. All said and done I'm glad I used this method, I was going to buy a new 3-jaw anyway so I'm not losing out on much. I may try my hand at machining my own backplate as a project in the near future. If I wasn't in the time constraint I'm in I definitely would have taken longer than 2 weeks of oiling with pressure overnight. Thanks again, guys, I hope this thread can help someone in the future.)
