Paint comes from the store way too thick. Usage increases exponentially with thickness. (I don't know that for a scientific fact. Just my observation). The manufacturers do that so that noobs get solid coverage, and they don't get complaints. They don't mind that it uses more paint either. Add enough water for it to run like heavy milk. Not syrup.Well a couple hours ago i decided to get up and do the last coat on the walls. Took about an hour to do a second coat where needed. I basically did the ceiling and the paneling. I am not happy with how much paint i used just for this area.
That is the plan. Im doing the floors tonight.When you do the floors, you'll probably want to run it up on those cinderblocks, too. That will help keep out moisture.
I got up this morning to check the damage and see if how much of a second coat i will have to do. Looks pretty good. Floor will need a second coat for sure due to the wear it will take in general. One section i am not happy with though as it did start to peel and crack.
