- Feb 1, 2018
- 1,867
I used to buy Phenoilc from https://precisionpunch.com/ and off McMaster Carr. I bought the Moglice from Moglice.com
I would but the Epoxy they recommended for the product, but any 24 hour dry time epoxy should work. I have used JB Weld and 3M Scotch Weld. 2216 - 2 part gray epoxy for Phenolic and I can't find the 3M number but it's the same as the 2216 but it's green for Turcite. I buy Rulon from Tstar.com and use the epoxy they make as it has .003" glass beads to get a .003" bond line. They sell Phenolic too. I bet if you call a local plastics distributor and ask if the have grade Linen Phenolic they will have it. It comes in several sizes. I don't buy thinner then .032" You have to buy a sheet of it. If they cut it they charge a cutting fee.
