- May 16, 2015
- 162
I’m just wondering if someone changed the size of one of the gears to cut a special thread
I have only cut 'normal' threads and the QCGB is correct. The gears also match the Atlas parts list. The 24T gear runs the saddle L->R which is opposite normal threading and the 20T is engaged for L<-R.I’m just wondering if someone changed the size of one of the gears to cut a special thread
If there are n teeth on the driving gear and m teeth on the driven gear, the ratio would be 20/n x 24/20 x m/24 in the first case and 24/n x m/24 in the second case. In either case, the overall ratio is m/n.In the first pic the 20 drives the 24 then the 24 drives the rest of the gear train and in the fourth pic the 20 drives nothing and the 24 is driven by the spindle and drives the rest of the gear train in the opposite direction so in my head the elimination of the 20 definitely changes the ratio as well as direction of the rest of the gear train but I’m not fully coffeed up yet.
