OK, moving right along, the bearing retainer.
Found about a 24'' square x 1'' aluminium on the shelf. Grabbed a 6 x 6 chunk of it.
And found a 6 x 6 x 1/2 chunk on the scrap shelf to use as a fixture plate, was a fixture for another project. Mounted it up in the vice and faced it off.
Drilled & tapped the fixture plate and drilled the work piece to match.
Did a quick facing skim cut, about 0.005'' just to flatten it out.
Then bolt down and remove the clamps. Run a quick air cut to make sure the tool will always clear the bolt heads.
Rough pocket the center, 10 IPM, 2400 RPM, 0.0015 chip load, 0.050 stepover, 0.895 DOC
Then rough out the outside.
And a finishing pass, helical down cut, about 0.25 down per rotation.
Then bore to finished size for a good bearing fit. 4.5'' is about the limit of my boring head with the tool vertical.
Then flip the part over and counter bore the screw holes 0.350'' deep.
And done!
