- Aug 14, 2020
- 62
Thanks for putting these out Yuriy. I'll echo some of the other comments, I like the shorter length and keeping things in concise chunks. Production looks very good.
The AI voice is quite good and it really didn't jump out until you mentioned it. So I don't think anyone will notice it unless they're looking for it and it doesn't detract at all from the video.
The volume was a hair low on the first one, and a bit higher on the 2nd. I compared to a recent This Old Tony video (which I think is a pretty good production standard) and his volume was right in between the 2 you've made so far. So I think you're right in the range.
I'd make a couple of suggestions, mostly around making it easy to find info:
1) I see you have a playlist of TouchDRO Basics that you've added this to. I'd suggest tweaking the ordering in that playlist to serve as a table of contents for the info in a basic-advanced progression. Or perhaps start a new one with that in mind.
2) Consider adding "chapters" to the videos to make finding specific subjects easier. It's simple to do with timestamps in the description and if someone's coming back to find a specific item, it will help.
3) Might be beneficial to add links in the manual on your site pointing to these videos as well. That will help people find the YT stuff from that end.
Awesome work, thanks again!
