Are you using the original flanges that came with the grinder? Possibly Jet has a proprietary flange for that model?
Randy
I was using the original stamped steel flanges. They were not very flat.
Randy
Looks like the roughing pass pulled in a bit as it hit the shoulder, or they deliberately undercut it in the roughout phase. I've seen many grinder shafts with that "feature". Most of the flanges are thick enough to not "fall" into the undercut, so it doesn't cause a problem, but if someone were to face off a bit from the outside of the flange, it won't bear on the finish turned area, but can fall into the undercut. This can cause some runout problems. Carefully making new flanges is an option if this applies to your case. A surface grinder is handy to ensure parallel faces on the flanges.
