- Aug 24, 2013
- 73
Would it be possible to mount a pilot bushing on the outside end of the headstock to guide the boring bar, then make a boring bar with the cutting tool in the center of the boring bar, similar to what they used to use to bore steam engine cylinders. Then you would have to loosen the cutting tool and move it by hand a small amount to take each small cut. since you are just truing the bore and not going for an exact diameter that should work. Possibly use a bronze bushing in the pilot bushing and grease it well.
