- Jun 10, 2019
- 542
I've been having a heck of a time trying to get a good cut in 4140 Normalized on a 2hp BP knee mill.
The cutter is a USA (?) manufacturer 0.5" diameter 4FL solid carbide endmill. I started with 0.5" DOC, 0.2" WOC, 12 IPM at 1400 RPM. Per FSWizard this is a Vc of 185 f/min, fz 0.0022 in/th, and MRR 1.25 in^3/min. I'm just hogging material - alternating between conventional and climb milling as I move back/forth. The few 0.5" carbide EMs I have used but reasonably good shape.
The finish seems OK but the chips are very dark blue (I'd actually say purple) and I get a good amount of sparking. I feel like its cutting way too hot; the part is getting somewhat hot too. I've played with the feed (7-15IPM), speed (1200-2000RPM), WOC (0.150" and 0.100", haven't tried higher than 0.200") : nothing seems to fix the problem.
Thoughts?
Thoughts?
