- Oct 29, 2012
- 1,392
Who knows something about transfer case sprocket and chain? I had the idea to use it to transmit some rotary power, as I found the specs for standard ANSI roller chain are actually not that impressive. I can't find any specs for the t-case chains and sprockets, but given they're used in vehicles making 400+hp from the factory, I assume someone has the numbers, and signed off on the components being grossly overkill for my application (just like I like it).
The sprockets look like ordinary spur gears. Are they?
There "seems" to be less than a handful of different pitches & chain widths, with most OEMs using the same parts in their transfer cases, so it "seems" as though you could potentially take a chain out of a dodge, a sprocket out of a jeep, and another sprocket with a different tooth count out of a GMC, and as long as they're all the same width, you could put them together for other-than-1:1 gearing. Am I deluding myself? Surely it's not as simple as that? Nothing is ever that easy.
