Not too important, but I should qualify my concern I guess. Way back when I bought my mill/drill, I had read that you probably would have to shim the column/base interface in order to make it right. So I made the indicator thing, and got to work shimming. After a few multi hour days, I thought I had it perfect. Then I spent three years making crooked parts, and filing them to fit, and assuming I just sucked at this, or the vise had a problem.
Long story shortened: When I moved, I took the shims out during disassembly and decided to leave them out. After all, everything I make is crooked anyways. What did it matter? Ha!
The mill is more accurate without my interference/indicator thing/shims. The end.
