- Aug 7, 2018
- 668
Hi Pcmaker,
Yes you do need to calibrate your device !
The technique is to put a parallel flat on the table and adjust one indicator so that it reads zero when the stylus is placed on it. You do this by rotating the scale. Then rotate the device 180 degrees so that the other indicator is in the same place and zero it the same way. You may need to use a mirror to see the other indicator since it will be facing away from you.
At this point the device is ready to use.
I've found it very interesting to put the device across the mill table and wind the table from end to end !
