Yeah I got some R8 collets with it. The drill chuck seems not too great....don't use the drill chuck that comes with the mill for tramming..
That's great to hear! So far I absolutely love it. It's not the biggest machine but I don't have much space in my garage anyway. I love the brushless motor and I'm sure it'll be awesome once I tram everything up and keep everything well tuned.I found the 3990 to be a capable machine within its limits. Actually does some things better than my full size Wells Index (shush , blasphemous)
However I found I really needed more Z so you may want to get a column riser block an only shim once !
I had the pleasure of doing it twice. Good luck with the 3990 I think you will enjoy it, just don't push it too hard and you can turn out very nice pieces. Slower than a full-size but very nice and we are not doing this for speed are we? Enjoy the process. I have my car/truck/bike hobby for speed...and the 3990 can turn out some great carb/manifold plates !
Depending on how the mill is set up, you should be able to machine the riser block with bosses at the bolt locations. This will eliminate the issues with step over artifacts. I would determine what was required for shims and shim the underside of the riser to raise the riser appropriately.I read a post from someone who made a riser block for their mini mill and machined-in the compensating tilt, eliminating the need for shims. He claimed to have done it by utilizing the as-given column tilt, but I don't believe that would work unless a fly cutter was used (to avoid stepping the cutter over); and even then, only for one axis -- the one that is not moved during the fly cutting pass.
You probably could do it If you determine the amount of shim needed for both axes and machined the riser block to compensate.
I own a mini mill with a tiltable column so the X axis can be easily trammed. Positives and negatives there because it also can be knocked out of tram. To make my mill a bit more rigid I made a 1/2" steel plate to replace the big Belleville washer that attaches the column to the mounting block, and as part of that I added a jackscrew setup to the bottom of the plate that enabled me to tram the Y axis. Within a small range, anyway -- it applies force between the column and base to do it. If my Y axis tram had been out quite a ways I would have shimmed it first to avoid the risk of breaking the column bracket (or worse yet, the base itself).
BTW, even if you've got a very crappy drill chuck it doesn't matter when it comes to tramming your mill (unless the chuck is just plain loose somewhere). Since your dial indicator (DI) rotates along with the chuck, its plane of reference remains constant. This is the beauty of the single-DI method of tramming.
This is a really interesting idea. I'm not sure how well I would be able to execute this idea, but I would think this would be more solid than shims (probably not by too much though).I read a post from someone who made a riser block for their mini mill and machined-in the compensating tilt, eliminating the need for shims. He claimed to have done it by utilizing the as-given column tilt, but I don't believe that would work unless a fly cutter was used (to avoid stepping the cutter over); and even then, only for one axis -- the one that is not moved during the fly cutting pass.
Seems like I would have to be pretty precise with machining the riser block. I guess I would also machine the riser block after the column is shimmed/trammed to make sure it's square?Depending on how the mill is set up, you should be able to machine the riser block with bosses at the bolt locations. This will eliminate the issues with step over artifacts. I would determine what was required for shims and shim the underside of the riser to raise the riser appropriately.
