Hello everyone!
I just got a Littlemachineshop 3990 mini mill and it's awesome. I haven't actually checked the tram of the column yet, but I figure I'm going to have to tram it with shims.
I know these little mills suffer from less rigidity than larger machines, so I'm wondering if I should tram the mill with a solid steel filled epoxy at the base of the column to provide a more solid connection (like what Stefan Gotteswinter did on his mill:
The question I have is, is it worth it? I'm not sure how bad shims would be for rigidity, but on these little mills how much would I be gaining by using epoxy? Is it overkill on such a small machine?
