I appreciate the thoughts. I have a Craftsman 12” sliding compound miter saw. It’s ok I guess. I can’t say it’s particularly accurate, but it’s usually good enough. The problem always comes down to space. Because of the design, it needs like 16” (or more) of empty unusable space behind the saw. My shop is 9’ wide. I don’t know that a RAS is an answer. But it appears that when it’s not in use, I have a tabletop for whatever I may need. While with the miter saw, it’s taking the same space and hoarding it.I'm a long time woodworker, professionally. I've owned a lot of saws over many years. A radial arm was my first one. I still had a DeWalt model GE 14" when I sold out. A radial arm saw would be the last type of saw I would buy. Consider instead a Makita compound miter saw with as large a blade size as you think you will need. Safer, more accurate, quicker to change angles on & on. I
I do see a lot of saw blade sticking out on them. But safe operation is my responsibility. I mean right now, I basically triage most of my projects with the following questions.
1. Will I need the tablesaw?
2:Will I need the miter saw?
3:Will this take longer than one day?
If any of those answers is yes. The project is scrapped. Because I’m not going to set these things up and tear them down every day for a week to “have fun making stuff”. Lol
But I’m imagining the RAS could be there against the wall all the time. No set up. Just spitballing here. And it rips and crosscuts.
