TouchDRO V3 Almost Ready ...
ycroosh
H-M Supporter - Commercial Member
Apr 4, 2013
884
Hi folks,
I've been pretty quiet last few months, so I figured it's a good time to post a bit of a status update.
I've been head-down testing, debugging and polishing the new version of TouchDRO (AKA TouchDRO V3), and at this point the app is almost ready for public testing.
Google Play Store has a few different "tracks". The app that is visible in the store is in the "release" track, then I can have open beta and closed testing tracks. For several weeks now a dozen or so people had access to it in the close track, and at this point most of the major annoyances are ironed out. Mind you, I still have a two-page-long spreadsheet of bugs, but those are more of a "BlueTooth icon too small on 13" display" instead of the "the app crashes and sets the garage on fire when I zero out the X axis".
I posted some details on the recent additions and how to get into the closed testing track on the blog (see the "TouchDRO V3 Almost Ready" post) but if you don't feel like reading all that, the short version:
I made a bunch of improvements to the Graphical View that will make things like slot or pocket milling much more convenient. Namely, you will be able to add Guide Lines that can be used to automatically move tool radius compensation to the correct position and/or beep as you approach them.
Second, TouchDRO now supports electronic edge finder functionality. I added a convenient way to indicate a workpiece (any of the edges, centerline or center of a feature). Incidentally, the function works with plain old edge finders too, you just need to press the button at a different time. The process of finding centerline is:
  • Click to bring up the dialog
  • Touch off left edge; press the "left" button
  • Touch off the right edge; press the "right" button.
  • TouchDRO will select "Center" option automatically
  • Press "Set Origin"
Now that I can work with a touch probe, I have some other ideas for near future, but those will have to wait till after the release.
I would love to hear your feedback or suggestions. These functions are a bit of a new territory for me. They make sense to me when I use the app, but I'm not exactly my target audience.
Thank you in advance
Yuriy
The new version of the TouchDRO is really a big upgrade in many ways. Keep up the good work Yuriy!
One of the things I really enjoy about TouchDRO is the elegance of the GUI. What I can see of V3 is that that is getting even better. I’ve been using it a lot on my Clausing 8520 mill for the last 4 years and during the same time I’ve been using traditional, albeit older, DRO’s at the community college machine shop where I am a “perpetual” student. For me, TouchDRO is by far the more graphically understandable and more efficient tool on the vertical mill. I have decided to install TouchDRO on a Graziano lathe and a Bridgeport Series 1 mill that are new to my own shop, so I’m excited to know that v3 is coming. Thanks Yuriy for staying with the project!
@ycroosh
Have you considered (or maybe you already have done so) adding fractional inches as a display option? James (Clough42) was lamenting that his current project Hemingway kit has drawings with fractional inch dimensions, so I hopefully checked the current build to see if these were hidden somewhere, but alas not.
Including fractional inches as a quick selection (like mm/inch) could open TouchDRO to more applications in both woodworking and metal working. Maybe V4?
Thanks, Charlie
@ycroosh
Thanks, Charlie
Charlie,
I haven't though of displaying fractional inches, but it's very easy to enter them into the dimension preset. Most numeric entry fields accept simple equations, so you can just type "7/16" (without quotes) and TouchDRO will convert this to decimal.
Thank you
Yuriy
Hadn't thought of that – thanks!!
off topic but are stl files available for the new 3d printed enclosure to replace the plexiglass one ?
Will the new version be out in 3-4 months? That's when I hope my mill is back together. And after I recieve my New Lenovo m10 I'll just sit on it and not load any Touch DRO programs off of Google play until this new version is out.
V3 is on the PlayStore. You need to opt into "Beta" testing (there is a link around the middle of the PlayStore page).
