You may already realize this, but if you tap the display of a specific axis, you get a pop up with some additional functions, including a per-axis zero. I do agree that having that on the main panel is a good idea as it's a pretty common function.I finally got my scales (2 out of 4) installed and functional over the weekend and started playing with TouchDRO. (life just gets in the way sometimes). First thing I found myself looking for was the ability to quickly zero each axis individually, instead of the "zero all" button. So The new UI with zero set buttons on each axis on the main screen will be a welcome change. Thank you!
Yup, thank you. I found it. I was just saying having it in the main UI interface would be a welcome feature.You may already realize this, but if you tap the display of a specific axis, you get a pop up with some additional functions, including a per-axis zero. I do agree that having that on the main panel is a good idea as it's a pretty common function.
I guess I'm going to be "that guy".For the first suggestion (configurable axis buttons) I will need to experiment a bit to see how much work that would be. I contemplated removing the units button from there already, since I can't really think of a good use case when a person would want to have one axis in inches and another in millimeters. I might be able to make just the last button configurable relatively easily.
Thank you
Yuriy
Well, the good news is that I made it so it can work for all sorts of guys
I made it so there are three button placeholders next to each axis. For each of them, you can decide what buttons to show in that spot. This is configurable per axis, so you can have completely different buttons for X, Y, Z, and Alpha. Moreover, you can decide which buttons show up when the side panel is collapsed and expanded (again, configurable per axis
