The Bluetooth dropping out is probably due to the way the Android OS was implemented on the RCA tablet.I have theolder version of TouchDRO so I can't comment on the features. I originally used my MotoX smart phone for the readout and had no problems with the Bluetooth connection. I have since purchased an RCA tablet and the connection will drop out from time to time. My understanding is that the tablet will drop the connection if it sees a period of non-use. I also have my LG smart phone set up to display and it doesn't drop so I'm thinking that the tablet is at fault. It is irritating enough that I am thinking about using the USB connection option.
Here is the postWhere do I find that manual for the Chinese DRO on here?
Thanks Rata ..that is what I am looking at. It really seems like Touch DRO is more expensive than the Chinese offerings at this time. Just Igaging scales alone $200 or more for 3 axis. Then you throw out the Igaging displays, buy BlueDRO for $125 ...and then an Android tablet. So you are at least at the price of the Chinese packages. And you have capacitance scales instead of glass scales. So hence the questions regarding feature advantages. It does look like TouchDRO offers a tach feature that I am not finding on the Chinese units. Where do I find that manual for the Chinese DRO on here?
On my lathe, the only feature besides position that I use in the tool offsets (my toolpost is fixed on a solid riser block instead of the compound slide). I have an Acu-Rite DRO on the mill and use the centerline, linear/radial hole pattern, calculator, etc functions.So here is another question ...how many of the features do folks use other then a good readout of location ...when using a DRO?
Try and find one with a decent manual and replacement parts (scales). I’ve been talking to the guys over at DROpros and would go with one of their units if possible.So to keep this alive for a little while longer ....what about differences between Chinese units? Pretty much just the hardware? And how much difference?
