Wouldn’t you want to use position as your controlled variable, so variation in the fits of the frets doesn’t cause variation in their installed height after using force as the controlled variable?
Hello, I'm not following on what you said. You'll have to dumb it down a bit for me. When you say position do you mean the height at which I press in a fret? Are you saying press one fret in and then measure its height and then use that as the height to press in all the rest of the frets? If so then I don't know if I can do that. I figured the closest way to doing something like that would be to establish a consistant amount of pressure for each fret pressed in.Wouldn’t you want to use position as your controlled variable, so variation in the fits of the frets doesn’t cause variation in their installed height after using force as the controlled variable?
