- Aug 29, 2013
- 1,049
You could slow the RPM down a bit by changing the pulleys but still not slow enough to cut mild steel
I disagree with that. I used a combination of what Jack and Frank did. I added a shaft and changed the pulley on the motor. I got the SFM to 118 which works fine for steel. Oh, and I also use Lenox blades because they're made locally.
