- Jan 6, 2017
- 1,215
The toolpost indicator holders I see on thingiverse and being sold on Ebay have the dovetail as part of the 3d printed part.
I modeled some that can be put in a standard AXA/BXA tool holder. In case anyone is interested, I uploaded them to thingiverse.
The hole is just over 1/2" diameter x 1" deep, so the end-user can make a steel or brass threaded insert and epoxy into the hole.
It is modeled as a set, so one can be used for each position on the standard Aloris type toolpost.
I used 3 shells, 30% hexagonal infill and plenty of tree type supports to print these test versions.
The .stl file should be available here:
AXA BXA Toolpost indicator holder by Ken226
This includes one to fit each of the toolposts dovetails. Once for indicating the OD, and one for the face of the part. Print with 3 shells, at least 30% infill and use supports. The hole is for a threaded insert, which you can purchase or make using your lathe.
www.thingiverse.com
