I have a Themac, Dumore and a Dremel for metal lathe use. Each one has a specific capability. And each on has been used in my shop through the years. The Themac and Dumore are expensive even used and maybe not justifiable in the home shop. But if you need to grind something that can’t be tooled, well then it’s decision time and maybe no telling the wifey poo. I don’t like to grind stuff in my metal lathe because of the nasty swarf it generates but then I do not have a dedicated grinder for the tasks so I just carefully cover up the lathe before I grind. I made a lathe holder for the Dremel and for the piece of junk that it is, it does a surprisingly decedent job. Maybe the finish isn’t a mirror finish but good enough for a lot of projects…Good Luck.
