Ok a bit more info, I had about 1 minute to write the question guess I didn't do very good...
This is the tool I'm making
it compresses valve springs 2 at a time, hooks under the cam and the blade goes between the valve shim buckets and the ramp pushes the bucket down and locks on the flat so the shims can be changed.
I make them 6 at a time on a fixture
Each part is indexed on 2 pins and held down with screws, as it stands I used Alibre to design the part and Meshcam to do the CAM which is fairly limited in how it can set up the tool paths, it cuts the blade section down to finished depth then cuts the outline of the part in 3 passes of .040 each to get to the midline. The part is then flipped and it repeats the process to finish the other side of the blade and cut out. So it makes 6 passes at .040 plus the area of the blade plus it plunges strait down at the beginning of each pass. Mesh cam doesn't do lead in's or ramps just plunges and I know the plunges are not good on the tools.
Tools have been HSS or Carbide they last about the same I use up a tool on each side, if I try to get both sides out of 1 tool it breaks on the second side. I'm running flood coolant 1220 RPM and 4 IPM.
I use GWizard calculator for feeds and speeds.
My original question was would the tool life be better making 4 passes at .060 2 each side at a slower feed rate, I think about 3 IPM will still keep the tool deflection below .001 according to GWizard?
The other possibility I see is that all the plunges are killing the tool and less passes won't make any difference.
I'm in the process of learning Fusion 360 which is much more capable than the Meshcam is and I think I can set it up to plunge into a predrilled hole and eliminate the plunging all together, I just haven't figured out how to do it yet. It would be easy to add a few more holes in the program that pre drills the stock to fit the fixture.
How deep would you guys recommend cutting with a 3/16 endmill per pass?
Thanks
