I'm retooling a part I make and am thinking that taking a deeper cut slower may end up with less tool wear. The mill is a grizzly round column that was converted to CNC, The part is cut out of 1/4" mild steel with a 3/16 4 flute either HSS or Carbide, I get the same tool life out of either. I'm taking .040 deep passes 3 from each side and am thinking that 2 passes of .060 deep and slowing down the feed rate to maintain the same tool deflection may get me better tool life because I'm using more of the cutting edge. Is my thinking correct?
Also I'm going to try to predrill entry locations so the tool wont be plunging into the material, If I can figure out how to manually place the leadin's with Fusion 360.
This is all happening as a learning tool for Fusion.
Thanks
Brian
Thanks
Brian
