Tool holders
That would be great, Private Message me when it's satisfactory to you.
Does the cam lock when turned counter clockwise so as to tighten when in use?
You turn the cam into the lower section of hss bit so as it pushed the tool steel into the thicker part of the wedge .Also this provides a bit of a mistake factor if the tool grabs it will simply try and undo the cam rather than tighten it .I have don some pretty heavy cuts with one of them and in normal operation it does not move .3.5 mm cut feeding by hand
There is also plenty of clearance on the bolt head when facing . not the best pictures but you will get some idea
That's an awesome cut. Looking forward to your sketch, I'll try to make it work. I needed an inspiration.
Tom
