- Sep 29, 2014
- 2,102
Does it bottom out on the compound or on the toolpost itself?
I agree with you about cutoff tools, but I'm going to have to disagree with you on turning tool height. I have found that under some circumstances, going way below center works very well. I'm still not sure why it works and flys in the face of what we have been taught.
Jim, I've seen threads where guys have gone negative on tool height but nobody came up with a reason why they thought it worked, either. It seems to me that the only reason for doing it would be to improve front relief and reduce rubbing; this would improve finishes I would guess. Otherwise I'm having some trouble with why this works better than staying on center line, mainly because I don't understand how the cutting forces would be affected by modern tool geometry with the tool set so low. I'm not trying to put you on the spot; I'll just have to try it and see if I can sort this out for myself.
Lots of guys, especially the real old timers, also set tool height a bit above center, usually quoting How To Run a Lathe as the reason. South Bend recommended setting the cutting tip 5 degrees above center for straight tuning and this is like the bible for some guys. The problem with this is that they used lantern tool holders that held the bit at an upward angle and ground the front relief with up to 15 degrees to allow the tool to cut. With modern cutters and tool holders I'm not sure this recommendation still applies but this is why I said the cutter should be on center height ... but it may not be.
Yup, and I'm one of those old timers and went by How To Run A Lathe also, that and my 70 year old shop teacher in high school. That's been a few years ago. I discovered this trick by accident one day when I inadvertently allowed the height nut to back up on my tool holder. It was cutting just fine and no spring, but I wanted to touch up the tool for another operation and on putting it back on the tool post, I reset it to the normal ''just above center'', the old problems came back, complete with tool spring and the normal issues.
Since I was just taking roughing cuts, I started thinking, what happens when I lower the tool? I started lowering the tool on each pass until I got no spring and was getting a nice cut. When I finished that operation, the tool was actually about an 1/8 below center. I measured after each pass and it was taking exactly what I dialed in with no spring at all. In this case the part final dimension was 2.700, I have also lowered the tool when cutting smaller (down to about 0.500) diameter. If you went too low on a very small diameter I expect the the work would try to climb over the tool. I have no idea what is optimal as far as height, but just experimenting until it feels right is probably the best way.
I still can't explain why it works, but it seems to work. Just try it on a piece of scrap and see what your experience is.
